Monsoon experts ( inside)
Old Dec 7, 2003 | 02:36 PM
01Z0H6's Avatar
Default Monsoon experts ( inside)
Please help if you can.
started out with crackling in my front seakers.
replaced them with Alpines, still crackled.
bought another factory monsoon amp, still crackles.
Where do i go from here!!!?
Please help, i want to keep the factory stereo.
what next? TIA..............
Old Dec 7, 2003 | 03:41 PM
Rogue Leader's Avatar
is the crackling at all volumes??
Old Dec 9, 2003 | 06:36 PM
01Z0H6's Avatar
No! If i turn the volume "very" low you cannot hear it.
However when i increase the volume they ( now both fronts) crackle like crazy!?
It is worse on the pass side. but now it seems to be moving to the drivers side, only not as bad.? What can i do?
TIA........
Old Dec 10, 2003 | 11:33 AM
VIP1's Avatar
Copy & Paste Moderator
Check all the grounds and other connects to make sure they make good clean firm contact. A bad ground or connection can cause crackling.
--VIP1
Old Dec 10, 2003 | 07:08 PM
sleek silverado's Avatar
I had a similar problem with my EQ in my truck. I ended up buying a new one. It sounds like the POT on the volume control is worn out. This is just a guess. Try hooking up another radio temporarily to see if this is the problem! Good luck!
Old Dec 12, 2003 | 08:48 PM
01Z0H6's Avatar
hmmmmm, i'll try that thanks!
Old Jan 9, 2004 | 02:05 PM
rjerling's Avatar
Default I have the same problem with rear seat SUBS
I have the same problem with rear seat SUBS....
I replaced the SUB...... and the Monsoon Amp. Still have the same annoying rattle in the SUB......
I'm thinking it has to be the HU..... Any more ideas?
Old Jan 9, 2004 | 02:25 PM
tuffluck's Avatar
maybe the wires are at fault.
Old Jan 9, 2004 | 06:38 PM
Ah I doubt its the wires...
Id definitely more agree with what sleek silverado said, thats very very likely the solution.
