Calling All Carpc Gurus
Don't understand what you are describing with the monitor. Make sure you have the monitor supplied with the correct amount of power, and connect the USB from the monitor to the laptop. You might have to go into the monitor's menu system to see if there is something there. Also, make sure your monitor resolution is matched to the computer's output resolution.
You might want to test the computer with a regular monitor to make sure the computer really works.
