manual fan switch
Old Jan 6, 2010 | 11:38 PM
rich Z's Avatar
Default manual fan switch
Is a 20 amp switch enough for a fan switch? Thanks.
Old Jan 9, 2010 | 12:10 AM
ben77's Avatar
You can just get the SLP fan switch, plug n play and still retains stock operation.
Old Jan 9, 2010 | 06:13 PM
bigblock69's Avatar
The way I wired the switch on my car was to run a wire from the relay to a ground with a switch in the middle. I tacked into the wire that runs from the relay to the PCM. Its on the ground side of the relay. Run a wire from the dark blue wire on relay number 2 or 3 to your switch then from your switch to a ground. So all you are doing is manually controlling the relay to turn on the fan.
