SWI-x install help
Old Jan 11, 2010 | 04:12 PM
bluestreak17's Avatar
Default SWI-x install help
Hey everyone I have a 2002 Z28 with an aftermarket sony cdx gt310 and i bought the pac audio swi-x today so that i can use my steering wheel controls. Well I got the power and ground connected right and i tapped the blue wire coming from the swi-x unit with the blue wire coming from C3 slot 14 as seen here if you scroll down https://ls1tech.com/forums/stereo-el...nsoon-faq.html My main problem is that neither the camaro or firebird are listed in the instruction manual and im not sure if this is the right wire to connect i have done research and read about people using the green wire but most things i have found have been confusing. Which wire should I connect, the way it is now or to a wire coming from the steering wheel controls themselves?
Old Jan 12, 2010 | 12:00 AM
Pheonix's Avatar
Its the dark blue wire on the cars connector. Its almost singled out all by itself.
Old Jan 12, 2010 | 08:01 PM
Thanks my problem was that the wire tap i was using didnt tap the wire, got everything working and it works great. Anybody needing to know the camaro is version 1 for programming the swi-x
Old Jan 13, 2010 | 06:42 PM
Pheonix's Avatar
Mine is all connected but i cant figure out how to program it, lol I tried for an hour and gave up.
I have the pac-swi jack
