Hirschmann Power Antenna?
Old Jan 11, 2010 | 06:51 PM
Jake_the_Snake's Avatar
Default Hirschmann Power Antenna?
My original power antenna snapped and i was wondering if anybody has had experience with any of those antennas listed on ebay. price is about half the cost of an oe type antenna.
Old Jan 11, 2010 | 10:27 PM
wssix99's Avatar
Save the manuals!
You should be able to get a replacement mast from gmpartsdirect for around $30. Not sure what the part number is for a 96 - but the mast is a lot easier to put in than a new unit.
Old Jan 12, 2010 | 12:01 AM
pentavolvo's Avatar
i have installed them in 2 different f bodys no issues
Old Jan 12, 2010 | 12:51 AM
the motors bad too. makes a nasty grinding noise every time i turn on/off the radio. gmpartsdirect has the whole assembly for 105 i think. i bought this one off ebay for 52 shipped. i did some research and apparently hirschmann made the antennas for the old bimmers and mercedes so i feel a lil better about the purchase now
Old Jan 12, 2010 | 07:29 AM
wssix99's Avatar
Save the manuals!
Your motor is fine, so you should be able to get some money for it. The antenna mast has a plastic rack with gear teeth on it. The grinding you hear is the motor gear grinding on that plastic rack, which can no longer move because the mast is snapped. If you undo the nut at the top of the mast and pull on it really really hard when its trying to extend, the whole thing will pop out and the noise will go away.
Old Jan 12, 2010 | 01:15 PM
it didnt go up or down, even before it snapped. but i see what you mean. i'll have to take it apart and see. if all looks well maybe i can give it to my buddy with a non-power antenna. thanks for the input
