Headlight issues, lows don't work only highs
First step is to eliminate the bulbs as the problem. Unplug one low beam and use a test light or multimeter to check for power and ground at the bulb socket. The yellow wire in the connector is the low beam power. The black wire is ground.
If you have power and ground then the bulbs need to be replaced. If you don't then you'll have to start troubleshooting with your test light or meter. You can eliminate most of the circuit because it is common with the high beams and they work. The headlight switch and dimmer switch must both be working. The only thing left is the sockets themselves (check for corrosion) or the wiring between the main under-dash connector and the lights.
