Need to replace front door speakers
Old Jan 30, 2010 | 08:59 AM
Shackleford's Avatar
Default Need to replace front door speakers
Do I have to take off the entire door panel to get to them? What replacement speakers do you recommend? Any relatively cheap, store-bought ones? Thanks.
Old Jan 30, 2010 | 11:23 AM
cfallsguy's Avatar
https://ls1tech.com/forums/stereo-el...-speakers.html
And anythings better then stock. Phoenix gold's seem to be popular and a few others i can't think of off the top of my head, but search around for component speaker ideas, they're all over this site.
Old Jan 30, 2010 | 11:42 AM
Anything good at Wal-Mart? lol.
Old Jan 30, 2010 | 01:13 PM
nemss1's Avatar
no no to walmart. try kee audio
Old Feb 5, 2010 | 08:29 PM
99 ss's Avatar
mtx is great also
Old Feb 6, 2010 | 01:36 PM
ArkBird96's Avatar
I wouldn't buy speakers from Wal-Mart. If you want the best bang for your buck, and have a more-or-less stock Monsoon system, the Kee Audio Basic Package or at least the CDT components that he sells (I think the CL-6 is what he uses in the basic package) would be your best bet.
Be aware though, that you will NOT be using the crossovers that come with whatever speakers you get because of the way the Monsoon system is designed.
Old Feb 7, 2010 | 03:48 AM
thecobrahunter's Avatar
Like ARK said, if you replace the stock speakers with aftermarket ones, you will not be utilizing the Monsoon amp/crossovers.
Old Feb 7, 2010 | 08:41 AM
WhiteBird00's Avatar
Ungrounded Moderator
No, the other way around... if you replace stock speakers with aftermarket you will not be using the crossovers that come with the aftermarket speakers. The Monsoon amp does all signal filtering internally except for the tweeters on Firebirds which have inline high-pass filters.
Old Feb 7, 2010 | 11:31 AM
cfallsguy's Avatar
So if you buy a set of components for the door speakers how would you run the tweeters w/o the crossover? I forget how the door speakers are wired with the amp. Four sets of wires i think? Two for speaker two for tweeters? Not sure.
Old Feb 7, 2010 | 12:01 PM
Just leave the crossover out. The door speaker wiring is split into separate channels for mid and tweeter - two pairs of wires in each door. The signal to the tweeter wires is already filtered (by the amp in a Camaro and by inline high-pass filters in a Firebird) so additional external crossovers aren't necessary.
Old Feb 8, 2010 | 05:44 PM
LS1 Sounds's Avatar
With the Kee Audio basic package components, would it be worth it to extend the tweeter wiring and locate the tweeter farther up in the door panel? I'm thinking of cutting a hole right in front of the Camaro door handle and flush mounting the tweeters. Good idea or no?
This would keep them somewhat hidden below the window and door lock switch's protrusion, but high enough for the sound to clear knees. I can take a picture if needed, this would apply to any component speakers really.
Old Feb 8, 2010 | 10:12 PM
cfallsguy's Avatar
This is what i am thinking about doing come summer, and have seen some clean installs. Don't see why it wouldn't work just extending the pre-existing wires.
Old Feb 8, 2010 | 10:26 PM
PIZDETS's Avatar
I vote for Kee also
