Ground for an amp
Old Dec 30, 2003 | 11:48 PM
NBM2001z28's Avatar
Restricted User
Default Ground for an amp
In a 2001 Camaro, where the hell would u put a ground wire if the amp is goin to be on the platform right behind the rear seat?
Old Dec 31, 2003 | 01:22 AM
slik98z's Avatar
i put mine in the back, near the rear side panel that covers the spare tire (now nitrous tank). if you look in there, there are plenty of places to put a ground as long as the wire is long enough for you. otherwise, i just used a self tapping screw and sanded down an area on the flat part of the rear, between the t top holder and rear side panel (where the spare goes) and drilled it in there, it laid flat, very neat, just so happens that i ended up putting a bracket for the nitrous bottle in that hole and put the ground on top of the bracket, and it was a great and strong ground. good luck
~Travis
Old Dec 31, 2003 | 08:12 AM
LS1Baron's Avatar
Slik98z has the right idea. I ground two amps to that location with no problems.
