Fog lights
Old Mar 21, 2010 | 01:55 PM
2000ESES's Avatar
Default Fog lights
does any one sell bright *** fog lights?
Old Mar 21, 2010 | 03:17 PM
1995blacktattop's Avatar
who puts fog lights on their *** much less bright ones? j/k
seriously though i think i have seen people replace their whole fog light assembly with PIAA lights or something similar.
Old Mar 21, 2010 | 03:56 PM
samson_420's Avatar
H.I.D. < says it all
Old Mar 21, 2010 | 06:44 PM
dochidalgo's Avatar
The best option is Xenon system (same installed in my 97 TA). The bulb is the 880 and you decide if you want bright white 4500°k or 6000°K. Blue 8000°K. Another colors are "ricer" in my particular point of view. The upgrade is intended to get a better illumination on the road and hence, becomes a security issue.
Another option is replace your fog housings with KC Hilites Air Dam Series. They have a 100 watts bulb aimed low you will have almost a headlight-like beams. A friend of mine installed in his TA upsidedown with the stock bracket. The diameter is 5" round.
Links
http://www.summitracing.com/parts/KCC-417/
http://www.summitracing.com/parts/KCC-415/
Regards
dochidalgo
Old Mar 21, 2010 | 06:48 PM
89BluIrocZ's Avatar
i have HID in mine.
Old Mar 21, 2010 | 07:17 PM
dochidalgo's Avatar
89BluIrocZ Beautiful LS1 TA....Mine is an Artic White 97 TA with BiXenon in the headlights, Xenon in the fog lights 6000°K like yours.
Regards and congratulations
dochidalgo
Old Mar 21, 2010 | 07:41 PM
89BluIrocZ's Avatar
thank you sir.
Old Mar 22, 2010 | 06:17 PM
2000ESES's Avatar
does the wattage matter my cars fog is similar to 881 and where are you guys shopping for these?
Old Mar 22, 2010 | 06:33 PM
Disciple's Avatar
Check it out...my fog light project.
They have been kick *** in real fog and as opposed to HIDs, I can leave them switched on and have them flash when I unlock without worrying about killing the system.
https://ls1tech.com/forums/appearanc...ll-w-pics.html
Old Mar 22, 2010 | 06:41 PM
lemons12's Avatar
Easy solution to that is turning the fogs off when you get out = no flash when you lock doors.
Hids over everything.. You can get a quality kit to go in your stock housing for around 40-50% depending on options.
If you have a camaro go 55 watt, if you have a TA go 35 watt. Go to ddmtuning.com. By far the best place to buy from. Complete plug-n-play. NO halogen light can compare to hids, period.
Old Mar 22, 2010 | 10:48 PM
89BluIrocZ's Avatar
Agreed. I bought mine from DDM I have had them over 6 months. And I don't cut them off when I get put of the car either. I let them flash with my alarm. Nevere had any problems with them. And hell for $35 I figure I've already got my moneys worth out of them.
Old Mar 23, 2010 | 06:14 PM
2000ESES's Avatar
what kit are we talking here lemons12 would it be the Apexcone Raptor HID Kit
Old Mar 23, 2010 | 09:42 PM
89BluIrocZ's Avatar
probably the DDM kit. its got the slim Ballasts which really come in handy.
Old Mar 23, 2010 | 10:37 PM
trx250r's Avatar
Bore the hole out and put some IPF 900MSR lights in there. I have them on my truck and they are blinding from 1/2mi away and brightly light up reflective things like stops signs well over a mile away. Subbie style. Other than that other good ideas have been taken.
Old Mar 24, 2010 | 06:33 AM
lemons12's Avatar
Yes, the raptor kit is their regular kit. On our cars you have enough room two mount four ballasts very easily without being noticeable at all, two for low beams and two for fogs. If you want to save a little bit of money go with the regular. If you don't care and want the slims, spend the extra bit and get those. Most people are in a craze over slim, I guess they think they are better...? Quality wise there is no difference. Other reason I guess is cause they think they regular is too big for our cars. Like I have said WAY more than enough room/places to mount these on our cars.
The DDM kit has a choice of slim or regular.
