amp/subwoofer power cable routing
Old Mar 23, 2010 | 11:04 PM
PRiCK's Avatar
Question amp/subwoofer power cable routing
I know this has been asked before. However, searching the previous threads, I couldn't find a definite answer.
In my '95 z28, I put the amp power cable threw the firewall hole under the PCM and ran it to the red aux. power (positive) terminal near the battery, and all was well.
Now, in my 2002 ss, I found the same hole under the PCM. But the aux power terminal is on the driver side near the front head light. Here's my question:
Should I (A) run it threw the same passenger side firewall hole then directly to the battery? or,
(B) run it through the passenger side firewall hole, past the battery, under my CAI and hook it up to the aux. power terminal? Or,
(C) (more of a question) Is there a hole in the driver side firewall I can run the power cable threw directly to the aux terminal?
Thanx in advance
Old Mar 23, 2010 | 11:08 PM
trx250r's Avatar
I would run it straight to the battery unless its a fairly small amp
Old Mar 23, 2010 | 11:09 PM
LS1_Sean's Avatar
On my old setup in a 99 camaro i drilled a hole on the drivers side and got power from the AUX terminal. (This was before i knew i could go by the pcm)
I would suggest goin through the PCM and connecting directly to the battery.
U can do it both ways but (A) would be the easiest
Old Mar 23, 2010 | 11:18 PM
SuperSport346's Avatar
I have my setup going right to the battery.
Old Mar 25, 2010 | 12:45 AM
PRiCK's Avatar
i will definitly hook it up to the battery. I just need to find the correct battery side post adapter. Anyone know the correct size or a link to the one I need?
thanx
Old Mar 25, 2010 | 12:55 AM
bigj2717's Avatar
Go to autozone or even wal-mart and with the car stereo stuff they'll have the side post adapters their all the same
