16 volt alternator Would this be good for a high powered system or would it burn out my pcm and other electronics? |
Very, very bad idea. You'll burn up all manner of stuff. If you have problems, increase the diameter of the wires supply power to your stuff so that you can carry enough current and not have a voltage drop due to wire length. DO NOT try to fix it by stuffing more voltage through it. When I say increase wire size, I'm not talking about on the audio side of things. I'm talking about the power side. I you're NOT having problems, then you won't see any benefit from increasing wire diameter either. |
ok, Im building a turbo system that has the alternator relocated to the passenger side valve cover and want to get the biggest that can fit. I might sell the bracket so I can get the speed inc bracket. I also have a bunch of electronics and need a 250 amp alternator. |
Here I purchased my 200 volts alternator, new. You deal with the owner. Fair price and excellent service and support (non-sponsor link removed) Regards dochidalgo |
Originally Posted by dochidalgo
(Post 13099787)
Originally Posted by pdasterly
(Post 13099503)
ok, Im building a turbo system that has the alternator relocated to the passenger side valve cover and want to get the biggest that can fit. I might sell the bracket so I can get the speed inc bracket. I also have a bunch of electronics and need a 250 amp alternator. You can actually get more output at idle from a 200 amp alternator than from a 250. The 250 generates more power at higher RPM but not as much at idle. |
Originally Posted by WhiteBird00
(Post 13099817)
That would be a 200 amp alternator. 200 volts is more than in your house. *I meant to write 200 amperes 140 volts. *I appreciate that the sponsors were more specific with the products they sell. I ignored KITT is actually a sponsor. My apologies dochidalgo |
If you get a bigger alternator you should also upgrade the big3 |
big three upgraded, 0 gauge wire used. The alternator im looking at has approx 180 amp at idle |
(Post 13099863)
Sorry for my 2 mistakes: *I meant to write 200 amperes 140 volts. *I appreciate that the sponsors were more specific with the products they sell. I ignored KITT is actually a sponsor. My apologies dochidalgo BTW, it's not 140 volts. :jest: |
(Post 13103601)
Just yankin' your chain man. :D BTW, it's not 140 volts. :jest: I meant 140 amps alternator LT1 stock...12 volts...:bang: I need to check my Alzheimer condition:confused: Regards dochidalgo |
What kind of setup are you running that you need 180a at idle? You should also get another battery or 2. |
I have two batteries, my amp has a 500 amp fuse on it. The other amp has 120 amp fuse rating. I bought to big an amp so i'm trying to make it work |
© 2024 MH Sub I, LLC dba Internet Brands
