Front Speaker Help
Old Mar 28, 2010 | 04:51 PM
V6Bird4eva's Avatar
Default Front Speaker Help
Will these speakers work on my 1999 Pontiac Firebird?
Driver Complement
Mid/Woofer 1 - 6-1/2" Diameter (16.51cm)
Tweeter 1 - 3/4" Diameter (1.91cm)
Soft Dome Tweeter
Electrical
Overall Frequency Response 55-22kHz
Nominal Impedance 4 ohms
Power Handling (continuous) 60 w
Power Handling (peak) 180 w
Efficiency 92 dB
Driver Mounting Depth
Top Mount 2-1/16" (5.24cm)
Bottom Mount 2-5/16" (5.87cm)
Grille
Height 9/16" (1.43cm)
Diameter 6-1/2" (16.51cm)
Cut-out
Driver Cut-out Diameter 5-1/4" (13.34cm)
http://www.polkaudio.com/caraudio/specs/ex365/
Old Mar 31, 2010 | 12:18 AM
V6Bird4eva's Avatar
anybody know
Old Mar 31, 2010 | 07:33 AM
WhiteBird00's Avatar
Ungrounded Moderator
If you have a base audio system...yes they will work.
If you have a Monsoon system...you could make them work but they are far from ideal replacements. The Monsoon has component speakers in the doors - not coaxial.
Old Mar 31, 2010 | 11:35 AM
blackfbird98's Avatar
Driver Complement
Soft Dome Tweeter
Electrical
Efficiency 92 dB
Grille
Cut-out
hey man i have polk db675's in my front door i think they are discontinued now but they are awsome speakers, you can still get the newer ones and they are very affordable i would look into it on crutchfield.com i also dont have a monsoon but i rigged up 4" polks for my sail panels.
