hatch pop button not working.
Old Mar 29, 2010 | 01:53 AM
offroadfury6's Avatar
Default hatch pop button not working.
I have a '00 WS6, suddenly when we was changing the pushrods in my car, I noticed my hatch pop button wasn't working. I popped it right before I left the house to put my tools in the back hatch. when I arrived to my friends garage, it wouldn't work, hasn't for several days.
where is the first place I should check to start troubleshooting this issue?
thanks,
-Andrew
Old Mar 29, 2010 | 05:50 AM
wssix99's Avatar
Save the manuals!
The button goes bad. Unplug it and jump the connector with a wire to see if that will pop the trunk. If so, you just have a bad button.
Old Mar 29, 2010 | 01:05 PM
is the button a switch? if so, I should be able to just touch the two wires then, I'll try pulling it off later and put a meter on the wires, see if i'm getting power, I was just hoping it was an easy fuse or something.
Old Mar 29, 2010 | 05:09 PM
JM0523's Avatar
Mine does the same thing i have to push the button 3 or 4 times to get it to release the hatch
Old Mar 29, 2010 | 06:48 PM
wssix99's Avatar
Save the manuals!
Correct. button=switch Mine went bad a while back just like JM0523 is describing.
