Aux Jack Placement
Old Apr 8, 2010 | 09:41 PM
pontiacguy84's Avatar
Default Aux Jack Placement
Currently I have the Aux jack wedge between the center consoles and below the A/C controls. Not crazy about that, So looking for some ideas of where everybody has there aux jacks in their cars, pics would be greatly appreciated.
Old Apr 8, 2010 | 10:05 PM
Gordo78's Avatar
I've seen a hole drilled and it mounted next to the cigarette lighter. Not a wedge though, just the actual port.
Old Apr 8, 2010 | 10:54 PM
Fosnot's Avatar
if you know how to do it, you could pull put your center console and drill a hole and mount it in there, so its all hidden away?
Old Apr 9, 2010 | 07:33 AM
WhiteBird00's Avatar
Ungrounded Moderator
I ran an extension for my USB port under the console and mounted it in a hole I cut in the front edge of the armrest compartment. It's easy to reach for changing flash drives but it's completely out of sight. You might consider that for your auxiliary port if you don't use it for connecting something like an MP3 player that you need to see all the time.
Old Apr 9, 2010 | 07:06 PM
thanx for the info so far, heres the adapter i'm currently using, any thoughts or suggestions on how to mount it?
http://www.amazon.com/Male-3-5mm-Ste...p_ob_e_title_1
Old Apr 9, 2010 | 07:17 PM
disc0monkey's Avatar
by the coin dispenser
Old Apr 9, 2010 | 11:51 PM
Fosnot's Avatar
get some extension RCA cables, and either a custom wall plate style female port, and put it in the center console, works awesome
