Adding Factory Keyless and Alarm
body control module (BCM) (keyless entry receiver) (97-02 Camaro & Firebird) = 9353691
and
remote control door lock transmitter (keyfob) (with antitheft - RPO UA6) (96-02) = 16245100
BTW, you have to buy the BCM new or else do a VATS bypass because used BCMs can't be reprogrammed to match your ignition key.
If you're looking for something simple, inexpensive, and easy to install, DEI makes an alarm upgrade for keyless entry equipped cars called the Hornet 700T. It was marketed for several years by GM under their own part number. All of the connections except the siren can be made at the BCM, you retain use of the factory remote key fobs, and it will accept DEI accessories such as a perimeter sensor. You can find them online for less than $75.
