replacing stock ac/bose hu..having problems
your radio also has a blue/white wire called amp control or remote hook this wire to the blue wire from the gm harness and tape off the blue wire form the radio
done problem solved
the problem is the gm wiring harness is very generic to all gm cars had u had a non boze firebird with power antenna that wire would push the power antenna up and down
and on ur radio the power antenna wire only gets triggered when on the radio not cd etc
its a common issue people to see on cars with oem amps that have turn on wires not just f bodys but numerous diff makes and models
