Stealth box powerd sub.
Old Jan 8, 2004 | 12:28 AM
1F8TL02WS6's Avatar
Default Stealth box powerd sub.
Im getting a stealth box, with a 10'' MTX Powered sub. Do I just need to goto the local Best Buy or Cercuit city to get a wiring kit for it?
This is running into my stock headunit. How would I go about hooking this thing up? Like the wiring kit, how do I wire it, what about the factory amp, stuff like that. Thanks guys!
Old Jan 8, 2004 | 05:12 PM
SJLingenfelter's Avatar
Go to a walmart and just pick up a 8awg which is a 8 gauge wire kit and then run a splice from your left and right from your back speakers to your amp and there you go.
Old Jan 8, 2004 | 06:02 PM
ls1rocker's Avatar
yea i just installed mine, its really simple. i ran my power wire down through the grommet on the passenger side under the pcm (do a search for it) and that only took me about 15 minutes
then i tapped the driver side sail panel (in the back seat not the very back)speaker and ran that back to my amp. all in all it took maybe 2-3 hours tops, and i got my power wire from a electric motor repair shop i work at, so if walmart is out, you can try that -matt
Old Jan 8, 2004 | 08:37 PM
1F8TL02WS6's Avatar
Thanks alot guys. Im gonna doit on saturday.
