charging problem
Old Jan 9, 2004 | 09:03 PM
phenyxTA's Avatar
Default charging problem
I need some ideas. I can't figure out what wrong with my car. Every time I start it I have to jump it to get it started. It'll drive fine, and the voltage gauge reads normal. But as soon as I shut the car off, it's dead. The dome light won't even come on. I assumed it was the battery and replaced it but no luck. Any ideas?
Old Jan 9, 2004 | 09:36 PM
LS1Baron's Avatar
Check the parisitic draw on your battery. That will tell you if you have something pulling too much power. Otherwise, you have a bad alternator.
Old Jan 9, 2004 | 09:49 PM
phenyxTA's Avatar
Once the car is started it runs fine and stays charged. Wouldn't the alternator be what's keeping the battery alive when it's running? Also how do I check the drag on the battery? Thanks.
Old Jan 10, 2004 | 07:05 PM
firebirdude's Avatar
Sounds like a battery.... but if you've already tried that.... go to your local auto zone. They'll do charging system tests for free.
Old Jan 10, 2004 | 08:28 PM
phenyxTA's Avatar
Cool, I didn't know that. Thanks.
Old Jan 11, 2004 | 10:14 AM
Cokeroker's Avatar
also double check your battery relay.
check battery cable itself to make sure it is attached to your starter etc all good and tight.... no loose ends
Old Jan 12, 2004 | 06:57 PM
phenyxTA's Avatar
I had doubts about my 'new' battery from autozone so I swapped the battery in from my wife's Camaro. Fired right up. Someone is getting a new ******* ripped today.
Old Jan 12, 2004 | 09:51 PM
richieg's Avatar
Juat wanted to say thanks for posting the issue once you identified what it was. I'm glad it was just a battery and not something trickier. I trust autozone is replacing it for free.
