1 10" sub vs 2 10" subs
Old May 13, 2010 | 10:43 AM
tuffluck's Avatar
Default 1 10" sub vs 2 10" subs
i have 2 10" subs in stealth boxes. my car was broken into and my amps and deck were stolen, but police caught the guys on the run and they dropped my stealth boxes with the subs, so i have those back. i am going to eventually (when i move) replace the system with something more low-key. i was really just thinking HU plus a sub at about 500 watts. what is the sound difference between 1 10" sub in a stealth box at 500 watts, and 2 10" subs in stealth boxes wired in parallel at a combined 500 watts?
in light of my car being broken into, if the difference isn't substantial, i might just use 1 sub simply because if the car got broken into again, they wouldn't have more to steal. i know that's a funny way to look at it, but if you get your car broken into and stuff stolen, your perspective changes.
Old May 13, 2010 | 08:46 PM
BandDirector Blk98ZM6's Avatar
If memory serves, I think you're roughly talking about a -3 dB drop to go down to 1 sub with the same amount of power...
Old May 13, 2010 | 09:14 PM
99Bluz28's Avatar
You'll get the same output(2x wattage = +3db), except the 2 tens will move more air.
Old May 15, 2010 | 02:44 PM
tuffluck's Avatar
hrmm...so is it a +3db increase or is it the same? and what does move more air mean...i'm talking sound level difference, will it be noticeable?
Old May 15, 2010 | 06:31 PM
99Bluz28's Avatar
Thumbs up
One 10" sub with 500 watts rms will have the same Output(db level) as two 10" subs with 250 watts rms.
So if you double the wattage you get a 3db increase in output, and if you double the quantity of subs with maintaining the same rms wattage per sub you also get a 3db increase in output level.
And as far as moving air,you're more likely to physically feel the bass from two subs, since you're actually moving more air.
Old May 15, 2010 | 10:53 PM
shaun's Avatar
i had a mtx stealth box with a new model alpine type r sub with a 350w alpine v12 amp and it sounded really good and clean but now i have a vinyl wraped sub thump 2 12 box and it is louder(2 memphis pr 12's geting 600w total) but not all that much louder.
a really good 10 in a good box with good power will sound better than 2 fair subs with the same power.
Old May 16, 2010 | 12:05 PM
tuffluck's Avatar
i have 2 mtx subs that are okay. they sounded more than ample with 1,200 watts total. i'm scaling that back to 420 watts and really thinking just one sub will be a better option just because there is less overall power, and it feels a little silly to push two subs at ~200 watts separately. i'm considering a 10w6.
Old Jul 22, 2010 | 10:41 PM
I'm now getting ready to upgrade to 2 10" subs in my daily driver, so I need clarification:
I currently have 1 10" sub running off 2 bridged channels of a 4x50 watt RMS amp...so I'm currently sending a single 10" sub 100 watts. If I add the second sub, unbriged the amp, and send each 10" sub 50 watts each, are you saying I will NOT increase by 3 dB? I'm sending the same amount of power as before, but using 2 subs instead of 1. Or since I'm doubling the subs, using the same total power as before, I'll still see a 3 dB increase since I'm moving more air?
Old Jul 23, 2010 | 01:00 AM
99Bluz28's Avatar
No, you won't get a 3db increase in sub output since you're cutting the wattage per sub in half.
Old Jul 24, 2010 | 10:26 PM
owlpuff's Avatar
just a small note, every 3 dB == 100%
33dB is 100% louder than 30dB
Why this scale was made? pfft, beats me, but just keep that in mind that every 3 dB is double of the previous level
Old Jul 25, 2010 | 08:31 PM
Faze's Avatar
owlpuff- not exactly accurate.
"Thus, the threshold of human hearing (absolute silence) is assigned the value of 0 dB and each increase of 10 dB corresponds to a tenfold increase in intensity and a doubling in loudness."
3db would be an audible difference, but not a 100% increase.
Old Jul 25, 2010 | 09:46 PM
owlpuff's Avatar
Guess i used the wrong word when i said 'louder', but the dictionary is fine and dandy, but it fails to mention that sound is measured in a logarithmic curve.... make me get all technical now.. cause damn, i've only been doing a job for 4 years that requires precise control of dB in transmissions...
Below is a few facts about sound waves, A and C would relate to power radiating from the source, and B and D would relate to the Pressure that the wave creates.
a) A power ratio of 2 is equal to 3 dB. Conversely, a power ratio of 1/2 is equal to -3 dB. (NOTE: The -3 dB point is often referred to as a "half-power point," as when describing, say, a frequency response curve.)
b) A voltage or current ratio of 2 is equal to 6 dB. Conversely, a voltage or current ratio of 1/2 is equal to -6 dB.
c) A power ratio of 10 is equal to 10 dB. Conversely, a power ratio of 1/10 is equal to -10 dB.
d) A voltage or current ratio of 10 is equal to 20 dB. Conversely, a voltage or current ratio of 1/10 is equal to -20 dB.
pretty picture
Originally Posted by University of South Wales
Experimentally it was found that a 10 dB increase in sound level corresponds approximately to a perceived doubling of loudness.
in the end:
10dB is a perceived doubling of sound, 3db is making the sound wave 2x as big.
Old Jul 26, 2010 | 08:13 AM
WhiteBird00's Avatar
Ungrounded Moderator
in the end:
You are correct but most people don't understand the relationship between wave amplitude and perceived volume. Saying it takes 100% more power (watts) to produce a 3dB increase in volume (i.e. each doubling of power produces 3dB more volume) is something they can relate to. A 3dB increase is noticeable but not particularly significant - about the equivalent of one click of the volume **** on most car stereos.
Old Jul 26, 2010 | 02:39 PM
mudawg's Avatar
If you had a box like I got, it'd take 3 ppl to run with it! haha, But I also have 2- 12"s .
Old Jul 26, 2010 | 10:32 PM
LS-1Z28's Avatar
I have a 400 watt 10" in a stealth box and it's great... I mainly got it so I could hear and feel the music above my exhaust when I want. I think anything more would probably give me a headache hah.
I would definitely stick with the stealth boxes though so you still got a spot for the t-tops.
Old Jul 27, 2010 | 08:56 AM
DukesOfHazard's Avatar
Could always check out the t-top boxes off of sub thump dot com. I plan on building one soon and will try and take pictures when it turns out.
Old Jul 27, 2010 | 02:45 PM
mudawg's Avatar
yep, I got one of those in my car.
Old Jul 28, 2010 | 09:13 AM
tuffluck's Avatar
lot of talk about subs in a thread where the OP doesn't even own an f-body anymore
in my experience, the two 10" subs in 2 stealth boxes at 1200 watts was an insane amount of bass for everyday use. in most cases i had the bass set to -2 on the in-dash receiver. i think if you had one sub at 500-700 watts you would find that is more than ample.
i think the reason i posed this question in the first place is because i was so used to having a lot of bass/power that i didn't want to sacrifice what i had before unless absolutely necessary. but in reality, i had a bit overkill in my previous setup.
i think the t-top boxes are overkill too. keep the space for your t-tops, and get a quality 10" sub and amp and tune your system and you'll realize you don't need 2 12"s at 2000 watts.
Old Jul 29, 2010 | 03:53 PM
mudawg's Avatar
I got 2 12"s in a carpeted t-top box, with a 1440 watt amp under, roughly 700+ RMS( with my remote wire and power ****) Sounds crazy good, but Im a teen.... Likes it loud! ha
