Trunk button doesn't always work
Old May 18, 2010 | 02:35 AM
The Mighty Texan's Avatar
Default Trunk button doesn't always work
Does anyone else have this problem? The trunk release button will often require pressing twice to fully open the hatch, or will randomly not work. When the button doesn't work at all i have to turn the car off so i can take the wireless and hit the button on that to open. The remote always works so i'm assuming its the release button in the car. Wires shorting or something?? This has been going on for a while and i am finally annoyed enough to fix it now
Old May 18, 2010 | 06:52 AM
eseibel67's Avatar
I have the same problem. Annoying, but not enough to check into it yet. Not sure if the BCM gives the go-ahead in order for the switch to work.
Old May 18, 2010 | 07:03 AM
pjb's Avatar
pjb
does the parking brake need to be set to use the button?
I can't remember, I don't drive mine much anymore.
Old May 18, 2010 | 07:19 AM
DukesOfHazard's Avatar
Odd, the button inside my car won't work at all if it's running nor will the remote. I have to shut the car off to get either of them to work. Kind of a pain in the *** if you need to grab something out of the trunk.
Old May 18, 2010 | 07:48 AM
pjb's Avatar
pjb
The hatch will unlock when the button with the trunk
symbol is pressed twice within five seconds, as long as
the ignition is turned to OFF. If the ignition is on, the
trunk button will only worikf the transmissioni s in
PARK (P) for an automatic transmission,o r if the
parking brake iss. et on a manual transmission.
Remote Hatch Release (If Equipped)
Press the switch under the
lamp control below the
instrument panel to unlock
the hatch from inside
your vehicle.
I
If you have an automatic transmission, your shiflte ver
must be in PARK (P) or NEUTRAL (N) to use the
switch. If you have a manual transmission and the
ignition switch is in RUN, you must set the parking
brake before you can use thsew itch.
The switch only works when theig nition is in RUN,
ACC or when RAP is present. (See “Retained
Accessory Power” in the Index.)
the cut and paste came up with some misspellings, but you can figure it out.
sometimes the parking brake switch gets stuck and doesn't work right. when you pull the brake lever up you should see BRAKE lit in the gauge panel. if the BRAKE is not lit the car doesn't know the brake is set and the hatch release wont work (on M6 cars).
Last edited by WhiteBird00; May 18, 2010 at 08:14 AM. Reason: Merge consecutive posts
Old May 18, 2010 | 08:17 AM
WhiteBird00's Avatar
Ungrounded Moderator
Another thing to look into is a modification that adds an additional spring to the hatch release mechanism. This helps with the situation where you push the button and hear it work but you still can't get the hatch open (because it hasn't fully released from the latch). I did mine years ago but I can't remember where I found the instructions. I'm sure if you do a search for "hatch release" you'll be able to find it.
Old May 18, 2010 | 08:36 AM
http://www.installuniversity.com/ins...ease_fix_2.htm
Did it a couple months back and works really well now. I don't think my brake light is engaging when I put on the parking brake. I'll have to check that out later then.
Old May 18, 2010 | 08:45 AM
Coppertone's Avatar
I searched high and low for the instructions on this ^ but couldn't find it. Any help?
Old May 18, 2010 | 10:12 AM
pjb's Avatar
pjb
instructions for what?
Old May 18, 2010 | 10:41 AM
Coppertone's Avatar
on how to change the spring, what spring to use, etc....
Old May 18, 2010 | 10:48 AM
The instructions are in the link in post #7 complete with photos.
Old May 18, 2010 | 11:54 AM
bill12690's Avatar
as long as its tryin to pop and just doesn't get it compeltely, an extra spring is a great fix.. if its not even trying to pop at all, could be electrical.
Old May 18, 2010 | 07:20 PM
Danny2tek's Avatar
I added the second spring years ago, works like a charm
Old May 18, 2010 | 07:30 PM
MillerTime85's Avatar
The Extra Spring works everytime for me
Old May 19, 2010 | 01:25 AM
Ahh you guys are awesome thank you! Answers to all my questions.. Ill have to get that spring soon! Tired of pushing the button going back and pulling up then walking back to press it again haha
Old May 19, 2010 | 02:25 AM
bill12690's Avatar
lol yeah, i got lucky and just found some spring that worked great out in the garage.. you'll thank yourself..trust me.
Old Jan 10, 2011 | 10:28 PM
guy7bmwm83's Avatar
Thats exactly what I was doing. I installed the extra spring and the hatch opens properly now from the interior buttom.
Old Jan 13, 2011 | 09:10 PM
HoLLo's Avatar
All 3 of my birds have had this problem. How/Where do you install a spring and, what dimensions should I look for in a spring?
Old Jan 14, 2011 | 04:06 PM
It will take you longer to find it in the store than doing it.Heres a writeup
Old Jan 14, 2011 | 06:54 PM
HoLLo's Avatar
Awesome, thanks Miller
