Front Door Speakers crossover or AMP?
Old Jun 7, 2010 | 12:37 AM
ritchie919's Avatar
Default Front Door Speakers crossover or AMP?
Okay I own a 1995 Firebird Formula with the 10 speaker setup. I was wondering if anyone knew what that circuit board thing behind the speakers are? Because on each door the speaker wire which is green and light green connect to it then it goes to red wires that connect to speakers, and i guess mine broke so does anyone know what that thing is? is it a cross over or a tiny AMP? because i notice that my speakers dont work and i switched them some others and thiers like no bass at all in front door speakers no more.
Old Jun 7, 2010 | 07:49 AM
WhiteBird00's Avatar
Ungrounded Moderator
It's a high-pass filter for the tweeters.
Old Jun 7, 2010 | 12:57 PM
TireSm0ke's Avatar
Its essentially a cheap crossover, there are seperate wires for your mid driver and your tweeter. Your probably hooking up your mid driver to that xover and losing bass.
Old Jun 8, 2010 | 02:26 AM
ritchie919's Avatar
thanks you guys ima fix that ASAP because thier is still a broken piece connected to it so im pretty sure its messing it up. i get no bass what so ever from the front and i heard amping the front speakers cant be done or else i will blow the stock amp
