Security light problem
Old Jun 22, 2010 | 01:48 AM
HOT Z28's Avatar
Default Security light problem
Here is my problem, it happen couple of times already, for the first couple times I went to start a car and nothing security light is on and the car doesn't even crank. I played with the key, opened and closed doors manually and finally was able to start it. Today it happen again and nothing worked, I was sitting there for about 15 minutes trying everything I could, finally I disconnected the battery for about 30 sec. and it started and worked for the rest of the day.
Anybody had a same problem?
Old Jun 22, 2010 | 06:18 PM
JerseyLS1TA's Avatar
Yes I have, randomly too. Two weeks ago it happened, then yesterday and today leaving work. Unlocked the doors popped the key in and nothing, waited a few minutes and it the light went out and it was fine. Im nervous im going to be stranded somewhere one day bc of this. If you search LS1.com there is a fix for it
Old Jun 22, 2010 | 06:29 PM
rtr2001ss's Avatar
Does sound like time for a VATS bypass.
Old Jun 23, 2010 | 03:20 PM
HOT Z28's Avatar
Just did a search, found some good info about to try it on my car. Ill post the results later.
