passenger window help!
Old Jul 22, 2010 | 08:51 PM
94zGreen's Avatar
Exclamation passenger window help!
So my passenger window only rolls down. if i want i to roll up i have to switch the dark grey and the blue, now my question is why? it's such a pain.
i want to know where all the wires from the connector go to, this is the only diagram i could find just showing the wires, and my connector is hooked up the same way.
sorry if this is in the wrong section :/
Old Jul 22, 2010 | 10:00 PM
cbailey's Avatar
Maybe the part that connects inside the switch isnt hitting the terminals to make a connection and inverting the wires makes the other part of the swtich the up button. Seems like its time for a new switch.
What does the passenger side switches do ? Are they working correctly ?
Old Jul 22, 2010 | 11:42 PM
94zGreen's Avatar
um the switch when you press down it rolls it down, and then i switch the wires, and then i have to press it down again to roll it up, it's weird.
Old Jul 23, 2010 | 12:08 AM
SparkyJJO's Avatar
That's the switch on the driver side to operate the passenger window, correct?
Does the switch on the passenger side of the car work properly, or not?
Old Jul 23, 2010 | 12:25 AM
94zGreen's Avatar
no. drivers side, doesn't work. only on the drivers window it does
passenger doesnt work correctly
