Problems post Autotrix
Old Aug 1, 2010 | 11:19 PM
cep39's Avatar
Default Problems post Autotrix
So I just installed the autotrix passenger window fix kit, and at first everything worked great. However after ensuring proper window operation, I walked away from the car for around a half hour, and upon returning the window no longer worked, but I could clearly hear the relays clicking, both up and down. I checked the wiring, and everything is according to autotrix's directions. Prior to installing the fix the passenger window would sometimes work, sometimes not, so my question is do you guys think the motor just finally gave out despite working perfectly with the fix right after installation? I checked the fuse, but should I replace the relays? Thanks alot.
Old Aug 2, 2010 | 12:22 AM
porksoda's Avatar
Shake the relay and see if you can hear it rattling. Mine would click up and down also but turned out to be a relay had gone bad.
Old Aug 2, 2010 | 08:08 AM
69lemansguy's Avatar
im thinking its your motor
Old Aug 2, 2010 | 08:42 AM
cep39's Avatar
so if I shake the relay and hear it rattle that means it is good or bad? And I was hoping that it would not be the motor because it worked perfectly and quickly just after the install, and because replacing the motor seems like a huge pain in the ***. Is the method outlined in the sticky the best way to replace the motor?
Old Aug 4, 2010 | 08:23 AM
i thikn its in a sticky and LS!1howto. i just replaced the motor in my buddies bird, took maybe 45 mins? honestly the hardest part was taking the door panel on and off without breaking the cheap GM plastic.
Old Aug 4, 2010 | 08:35 PM
LS-1Z28's Avatar
this happened to me this weekend... but i realized that the window motor power connector had slipped off hah!
