Replacing entire Monsoon system
So, here are my goals/listening habits:
- Reasonable volume 95% of the time, but still want to be able to turn it up when a good one comes on
- Good sound quality
- Proper integration - no overpowering parts, just want a well thought out system
- Preferably one amp, but two can work
- Stealth box & T-top area amp rack
- No hatch speakers, I'm undecided on whether to keep the sail panels or not (opinions wanted)
Budget: ~$1000-ish for amp/sub/box/speakers however that is flexible. If I can get better quality for a couple hundred more, I'd be willing to put that into it. If I can get the same quality components for $1000 that I can get for $800, I'll go with the cheaper ones. The carPC is a separate budget and already taken care of.
Car is a 2001 WS6, if that matters. Thanks in advance for the help. I have been searching, but car audio seems to be one of those constantly evolving fields and what used to be great may be crap now, so looking for current opinions.
**PS**
Is there any benefit to relocating the tweeters from my door panel? Also, what are the inputs for the monsoon amp, does anyone know if its possible to hook a carPC up to the stock monsoon system and just remove the headunit?
CDT CL-61CV 6.5" Component speakers in the front doors $150
removed sail and hatch speakers $0
Kicker ZX200.4 amplifier (rated at 121W x 2 channels @ 4 ohms) powering components $125
Subthump Stealth Box $125
10" Alpine Type R Subwoofer 4ohm DVC $110
Kicker ZX400.1 amplifier (rated at 480W @ 2 ohms) $200
4AWG wiring kit and 8AWG wiring kit with 12AWG speaker wire + various conectors $75
That comes out to about $785. I also added about 150 sq ft of RaaMat and 7 yards of ensolite closed cell foam which put me at right about $1000 for a great sounding system. If you add in the Alpine CDA-9884 head unit that is about $1200 for a complete system (everything was self installed).
Also, make sure to remove the speakers from the hatch, as it doesn't benefit the Sound Stage at all
As far as the amp, Alpine makes a good 5ch amp and so does polk, other brands make some good product too. I'm the most familar with those two, as far as the polk (1100.5)... its an 1100 watt rms, 600w sub ch at 1ohm stable (does 2 and 4oh as well, just loses power output) and the regular channels are 80w @ 4ohm or 125w at 2 ohm. (alll in RMS)
So it comes down to finding the speakers to match the amp. Just make sure to find proper RMS rated speakers and subs.
At 1100w rms you could do a 4gauge power wire and still be fine (0g isn't that fun to run, imo)
