Alternator size/output????
Old Aug 8, 2010 | 06:42 PM
Steve Weisman's Avatar
Default Alternator size/output????
Sorry for the dumb question but is there a larger after market Alternator that you can hook up to a 2001 SS camaro. Having a stero system put in with 10 speakers including 2 12 woofers and I think a couple of amps. The installer said I will be fine but just trying to see what everyone thinks on LS1TECH, thanks , Steve
Old Aug 13, 2010 | 12:40 AM
sjsingle1's Avatar
https://ls1tech.com/forums/generatio...-failures.html
Old Aug 13, 2010 | 09:09 AM
tuffluck's Avatar
i purchased an alterstart HO alternator and i did that mostly because my stock was was surging (lights would constantly dim at idle with music off). the HO alternator was a waste of money. at low rpm's it did not provide more power than the stock alternator. unless you're up for spending $400+ on a well-built HO alternator, just stick to the stock one. bass notes via subwoofers will dim your lights some, but that is not a cheap fix unless you're willing to spend the bigger bucks.
Old Aug 13, 2010 | 10:37 AM
Default Alternator fix
Thanks for the help, going to put in the truck 145.
Old Aug 18, 2010 | 07:04 AM
Reaperchild's Avatar
sometimes JUNKYARDS are your fairy tale !!
