12v ignition source in the engine bay?
Old Aug 31, 2010 | 10:10 PM
soundengineer's Avatar
Default 12v ignition source in the engine bay?
sorry.. I just havent looked real hard yet...
is there an easy place to connect to a 12v ignition on source in the engine bay?
I need to wire something in, but only want it powered when the ignition is on and dont want to have to run the power wires back into the car..besides I've already tapped into the fuse panel for a 12v ignition source for something else.
Old Aug 31, 2010 | 10:33 PM
GO BABY GO's Avatar
On the top Pcm connector #19 is a pink wire is your PCM Ignition wire if I remember correctly. I beleive this will work for you.
http://www.flickr.com/photos/redwate...7624850923846/
Old Aug 31, 2010 | 10:46 PM
I'll be drawing a few more amps than that wire is rated for...need to have a thicker wire to go to..
prefer a fuseblock spot, just didnt know if one existed in the engine bay
Old Sep 1, 2010 | 07:26 AM
WhiteBird00's Avatar
Ungrounded Moderator
Use a relay.
Old Sep 4, 2010 | 09:08 AM
shoemike's Avatar
I've used the headlamp door slots for switched 12v under the hood.
They are not used in the Camaro.
Old Sep 4, 2010 | 11:14 AM
relay is in... just have to come up with the 12v ignition on power..
where is this power from the headlamp doors? and do the headlamps have to be on when I want the 12v...that could be an issue
Old Sep 4, 2010 | 12:45 PM
Danny2tek's Avatar
Here just use this open slot in the fuse box............
Old Sep 4, 2010 | 12:53 PM
perfect.. thank you...
now I just need to get my motor replaced..LOL
Blew up my LS1 a few nights ago... oil and smoke out the exhaust... I think I lost some rings...
oh well... its just an excuse for me to get the 408 I've been wanting to get but have been putting it off till I broke the LS1 >
Old Sep 4, 2010 | 01:26 PM
Danny2tek's Avatar
no problem
Old Sep 5, 2010 | 04:18 PM
If you're using a relay then you don't have to be concerned about current draw from the PCM wire as was posted earlier. Use the PCM ignition wire to trigger your relay.
