Fog Lights On Anytime
At the fog light relay in junction box 1 on the left fender under the hood:
- cut the brown wire, tape up the end that goes into the harness, connect the end going to the relay to a fused power supply (probably easiest to use battery power from the post on the junction box)
- cut the light green wire, tape up the end going into the harness, connect the end going to the relay to a good ground.
At the fog light switch in the dash:
- cut the brown wire, tape up the end going into the harness, connect the end going into the switch to a fused, ignition-switched power source (the best place is the spare IGN port in the fuse panel).
- cut the light green wire, tape up the end going into the harness, connect the end going into the switch to a good ground.
Now your fog lights can be turned on anytime the ignition is on without needing the other lights.
