adding old school high beam switch to 02 z
Old Sep 11, 2010 | 08:18 PM
reinhardt02's Avatar
Default adding old school high beam switch to 02 z
i recently bought an 02z to replace my 79 camaro. the 79 had the high beam switch on the floor and i really liked that. i am also having dificulty pulling the turn signal stick back to turn the high beams on.
so i was thinking i could install a floor switch on that hard plastic foot rest by the kick panel. seems straight forward- intercept the wires to the high beams before they go into the column and route them into the foot pedal. bolt the switch down to the foot rest.
am i missing anything? anyone done this before?
Old Sep 12, 2010 | 09:23 AM
wssix99's Avatar
Save the manuals!
There have been other threads about this in the past, but I recall everyone being talked out of it. You just don't have the foot room in a later model car than in a 79. That dead pedal is needed for a foot rest. You probably use it a whole lot more than you realize.
If you can wait a few years, we should be able to just use brain waves to control the thing: http://www.emotiv.com/apps/epoc/297/
Old Sep 12, 2010 | 09:28 AM
bad_408_vert's Avatar
Even If GM uses this mind reading tech, I wonder if the "breaking twig" of a sound affect would be incorporated into the cars just so we don't miss the sound of our current turn signal levers.
Old Sep 12, 2010 | 09:58 AM
VIP1's Avatar
Copy & Paste Moderator
I've seen it done twice. I was only able to find 1 thread where someone did it, but the pics are gone.
https://ls1tech.com/forums/appearanc...ere-floor.html
