monsoon system hook up with subs NEED HELP
Old Sep 17, 2010 | 05:10 PM
wildryno 69's Avatar
Arrow monsoon system hook up with subs NEED HELP
i dont kno much about sterios but my buddy and me are hooking up 2 re audios to a stock monsoon system. I already kno about splicing the wires with the speakers the wires are ran but i was told i have no rca cables in the back and when we hooked it up one sub was hitting harder than the other so we took them out looked it over and didnt see a problem...put them back in let them beat no problem. I was wondering what you guys think the subs were fine in a neon i owned.
2 re audio 12s
1500w audio pipe amp
Old Sep 17, 2010 | 05:13 PM
SparksAI's Avatar
How do you have your subs wired right now? What model of RE Audio are they? Did you use a Line Output Converter to convert the speaker outputs on the car or did you use high level inputs?
Old Sep 17, 2010 | 05:29 PM
i used the low imput from the back to subs
Old Sep 17, 2010 | 05:31 PM
line converter was ran off the stock woofer of the component set
Old Sep 17, 2010 | 05:36 PM
SparksAI's Avatar
How did you wire the subs? Are they wired together on the same channel or are you running them on two seperate channels?
Old Sep 17, 2010 | 05:48 PM
2gether i think i honestly dont kno that much about subs i kno it was playing good then crappy then good then crappy
Old Sep 17, 2010 | 07:19 PM
SparksAI's Avatar
To help you out with this maybe you can take some pictures of how everything is connected and post them?
Old Sep 18, 2010 | 09:39 PM
basicly im being told that since i dont have any rca cable and im running a output converter box its causeing my prob for a stck monsoon deck
