Gauge Cluster Not Working
All the grounds on the backside of the block are intact. I doubled checked all the fuses, everything looks right.
Could there be a bad ground somewhere? I have another gauge cluster, should I swap them out?
All the lights work on the gauges.
The odometer is showing up.
The speedo is stuck at 110 mph.
The oil pressure is pegged at 80+.
The voltage is pegged.
The fuel gauge is at empty.
The tach is at bottomed out.
