Need Help!!
Old Oct 6, 2010 | 11:53 PM
wm2002Z28's Avatar
Default Need Help!!
I have a 02 camaro. The problem is it's a manuel "no power" window s so how do i.take the door panels off?
Old Oct 7, 2010 | 04:03 PM
99greenls1's Avatar
still cant figure it out
Old Oct 7, 2010 | 04:09 PM
KEE AUDIO's Avatar
Behind the window crank between the door panel and the crank is a C-shaped clip that holds the crank on. You can slip a screw driver CAREFULLY in between and pop it out if you can see it or I recommend buying the correct tool to do this with available at any parts store for a few bucks. Here's a video of how to do it I found:
http://www.youtube.com/watch?v=7YyktubQKwc
Better then explaining it. Hope this helps!!
Old Oct 7, 2010 | 04:49 PM
99greenls1's Avatar
if you want il show you how to do it just tell me when
Old Oct 7, 2010 | 06:11 PM
wm2002Z28's Avatar
Thanks i got it now
Old Oct 7, 2010 | 06:12 PM
wm2002Z28's Avatar
What's up diego. I call and text you the other day
Old Oct 7, 2010 | 10:31 PM
99greenls1's Avatar
i got a new number
