Alpine type r 10inch subs
Old Dec 3, 2010 | 08:44 AM
94gt8er's Avatar
Default Alpine type r 10inch subs
I found 2 alpine type r subs online for $100.Ive looked them up and they have great ratings.So I was wanting to know if you guys have had experance with them and how they would sound in a 93-02 camaro.The reason I ask is because my buddy has some in his firebird and they dont hit like every body says they do, is his stuff set up wrong is that why they dont hit?He has them in a 93-02 camaro box,kenwood headunit,and punch amp.I need help!!!
Old Dec 3, 2010 | 09:00 AM
KEE AUDIO's Avatar
Could be the amp, could be the tuning, could be the enclosure, there are alot of variables as to why your friends doesn't sound the way it should. Those are good subs for the most part and for $100 for 2...that's a good deal. Just make sure they aren't damaged.
What amp and enclosure is your friend using? I know you said Punch but there are several models and years of RF Punch amps and some aren't as good as others. Also depends on how he has it tuned as to how it sounds as well.
You should be fine with those subs as long as they are in good shape.
Old Dec 3, 2010 | 09:09 AM
94gt8er's Avatar
This is the box he has and I have the same one except for 2 10's
http://cgi.ebay.com/CAR-AUDIO-DUAL-1...aultDomainQ5f0
Do you think the 2 type R's that I might get will hit in that.Also he has Rockford Fosgate Punch P500-2 amp.
Old Dec 3, 2010 | 09:12 AM
94gt8er's Avatar
Also if you think they will hit in that box what amp would you recommend I would get?
Old Dec 3, 2010 | 09:17 AM
KEE AUDIO's Avatar
Box is ok. I have a similar one I have used in the past. You will be ok.
Is it a newerP500-2 that is all black or the one with the chrome on it? The older model is the chrome one and was not RF's better days. The newer ones are pretty good. Either way it should hit. My bet is something is wired or tuned wrong and not so much the amp. He should be able to get around 250watts RMS to each sub when the subs are wired at 2ohms. Also check the frequency tuning and see where it is set on the amp. That may help as well.
Old Dec 3, 2010 | 09:22 AM
94gt8er's Avatar
Ok thanks alot.1 more question what amp should I get.They are the ones with the ripples in it if that helps.
Old Dec 5, 2010 | 11:32 PM
Koncrete's Avatar
If you have ever been in a car that really hits or to a car show the type r's are just never going to be like that... They are good for what they are, cheap *** speakers... Any 8" sub from a good company will blow away a 12" type r anyday of the week...
That said 100 bucks for 2 type r 10's is a good enough deal to keep you thumpin until you want to get serious about a sub
Old Dec 6, 2010 | 04:32 PM
KEE AUDIO's Avatar
That's a decent enough amp so I would now start looking at tuning.
There are a bunch of class-D amps so it more depends on the budget you have to work with.
