Can't program swi-jack to version 1
Old Dec 3, 2010 | 02:49 PM
APG12's Avatar
Default Can't program swi-jack to version 1
This is driving me nuts. I've been searching and searching and can't find anything helpful.
I bought a PAC swi-jack for my 99 TA with Alpine CDA-9886 HU a while ago but never installed it. I went to put it in today, got the connections hooked up, and went to program it.
Instuctions say I need version 1. I hold the program button, red LED lights up. Turn to ACC ON, release button, LED stays lit for a second or two then turns off.
Now it says to press prog button one time for version one. I hit button, nothing happens. About 10 or so secs later the LED flashed 3 times quickly, quick pause and one more flash.
I tried this a bunch of times but can't figure it out...
Old Dec 3, 2010 | 04:28 PM
ROCNDAV's Avatar
Did you hook up the blue and black (from the steering wheel switches) wire to the green wire ?
The purple and brown wires are to be looped (not cut)
Use these instructions: http://www.pac-audio.com/swixprogram...ehicles&ID=108
Old Dec 3, 2010 | 08:53 PM
APG12's Avatar
I hooked the black to black and red to red in the adapter harness, and green to the blue wire in the factory harness. I didn't use any other wires, and the purple and brown loops were not cut.
I was just thinking and might have figured it out. If the unit is hooked to switched power, then the LED shouldn't light up before I turn the ignition to ACC ON right?
Well mine does. I hooked it up to the red switched power wire in the adapter harness, but now I'm thinking that line is getting steady power.
Old Dec 3, 2010 | 09:08 PM
ROCNDAV's Avatar
Yup. The red wire has to be connected to switched 12 volts
Old Dec 3, 2010 | 09:11 PM
APG12's Avatar
I gotta check tomorrow. I know I hooked it to the 12v switched wire in the harness, so something's not right. But I appreciate the help!
