what size fuse and wire
I am going to assume that those amp ratings are peak for both amps, and Im going to assume they are both Class A amplifiers, so if they are not, ignore this, post back and I will redo this for ya.
I would place a 100 amp fuse straight off the battery with 4 gauge wire, and then run that all the way back to the amps. From there I would break off into 6 gauge wires, and put a 40 amp fuse on the wire going to the Sony and a 45 amp fuse on the wire going to the Rockford; however, if the amps themselves have different fuses on the actual amp, then use that exact same size instead of those I suggested.
Example: I said use a 45 amp fuse on the Rockford wire...if your Rockford amp has 2 25 amp fuses on the actual amp, then use a 50 on the 8 gauge wire instead of my suggested 45.
Let us know if you have any more questions.
Also! Make sure you dont exceed the fuse sizes of the manufacturer's specs.
Just my opinion.
