Dead Stereo OR Speakers?
Anyway, my question. Are all the speakers actually dead or is it something else? ... I have ZERO stereo knowledge so I'm sorry if it's a stupid question.
Thanks!
The RADIO ACCY fuse protects the Monsoon amp but this is not likely the problem in this case since you would still get some sound from the tweeters (which are powered directly by the head unit).
Don't rely on a visual inspection of the fuse - it can look fine but still be blown. Always use a tester or replace with a known good fuse.
The liklyhood of all four speaks blowing is little to none, I bet would be you got head unit problems. If you have a factory amp then that is also a possibility, check connections and verify voltage to the amp. I dont know about your year specifically but the amp is located in the wheel well around the spare tire.
If I am incorrect on the location I am sure some one will chime in and let you know.
