Where are you mounting your amps?
Old Jan 11, 2011 | 09:18 PM
MTBSully's Avatar
Default Where are you mounting your amps?
Well? I had a stealth rack in my last car and i liked it, but now i am toying with the idea of mounting it behind the rear seat or somewhere else. Still want to be able to store my t-tops. Post up pics!
Old Jan 11, 2011 | 10:56 PM
98z8uup's Avatar
This is where i have my 2 amps....
Attachment 273726,Attachment 273727,Attachment 273728
Old Jan 12, 2011 | 02:34 PM
cookba's Avatar
Old Jan 12, 2011 | 03:19 PM
tdevil55's Avatar
Got mine mounted on two brackets that hold the amp up, then mounted the cap under the carpet where the jack would go. Hid all wires under the carpet and in the spare tire area. Also, the speaker is self fabed into the divider so that there isn't allot of extra weight from a box of some sort. It actually sounds really good, it uses the entire trunk space as the box. The speaker is also ready for quick removal for when I want to take it to the track and have that little extra weight reduction. I know, its not super sexy in looks, but its rather clean and works well.
Old Jan 12, 2011 | 07:29 PM
sandsk8erz400's Avatar
Well, without the sub box, I'd be able to store my t-tops haha
Old Jan 15, 2011 | 08:30 AM
SLPHawk300's Avatar
Originally Posted by cookba
How did you mount this buddy?
Old Jan 15, 2011 | 10:52 AM
DAVE00's Avatar
That is exactly the same way I mounted mine. Just remove the spare and I cut a piece of plywood out and mounted the plywood to the spare tire mount and then applied sound deadening to the plywood to keep vibrations down. Then I mounted the amp to the plywood and it works out great. Only issue is I don't have a spare anymore, but it's not a DD for me so not a worry.
Old Jan 15, 2011 | 12:30 PM
slow_5.0's Avatar
this is how mines mounted, it kinda sucks with no t top storage but hind sights 20/20
Old Jan 15, 2011 | 12:42 PM
dutinsss's Avatar
do you ever have over-heating problems with it mounted there?
Old Jan 15, 2011 | 02:00 PM
cookba's Avatar
mine is done with some thick metal instead of wood since i drive aggressively and wanted the comfort of knowing nothing would come loose. Ive had that in there for a year now and its never overheated and i am from Florida and live in VA now, and we get hot.
Old Jan 15, 2011 | 09:37 PM
DAVE00's Avatar
Nope - there is plenty of air and room surrounding the amp once the trim is reinstalled. ZERO issues here and I push it pretty hard.
Old Jan 15, 2011 | 11:16 PM
bad_408_vert's Avatar
Impressive. I don't think I ever seen a car here on 'tech with subs and a cage all in one car.
Old Jan 16, 2011 | 12:08 AM
Vmineo's Avatar
Default re
Punch 75 one of rockfords best amps.I still use the 300/650's till this day
Old Jan 16, 2011 | 02:35 AM
thecobrahunter's Avatar
Mine:
Old Jan 16, 2011 | 02:42 AM
9WhiteCamaro9's Avatar
^ That looks good. I guess you had to do away with the spare tire though.
Old Jan 16, 2011 | 05:36 AM
98z8uup's Avatar
Yes it's a bad *** amp. It just give my poor little (P1-RF) sub hell.
Old Jan 17, 2011 | 10:12 PM
SLPHawk300's Avatar
Originally Posted by thecobrahunter
Mine:
How was it cutting that panel for that sub enclosure? I have the one in the "storage" area - but I'm thinking of putting my two Alpine stackable amps in that spot - and moving the sub to the other side...the panel in your car looks like it's twisted a bit after the cutting...
