Alternative Sub location
Old Jan 15, 2011 | 11:51 PM
kjcmusic17's Avatar
Default Alternative Sub location
Obviously the most common spots for subs are in the cubby hole or in the t-top storage area. Has anyone ever tried building a box that would fit behind the rear seats on the "hump?" (I think its the gas tank?)
The concerns I can think of when picturing this in my head are a) having the subs sit low enough so that visibility is not sacrificed or is a minimal loss b) having enough volume in the box to be adequate for the subs and c) making this look good
I don't know much about the physics of sub boxes and the volume of air required for efficient use of subs nor do I know if there are subs out their that are short enough to not make visibility an issue.
Thoughts?
Old Jan 15, 2011 | 11:59 PM
cfallsguy's Avatar
There are a few people who have done it right behind the rear seats but you can't get a whole lot of room behind it unless you do one 12" (maybe two but haven't seen it) or two 10" subs. And depending on the box height it can hinder seeing out of your rear view mirror. You could do a sealed 12" and that's really about it I would think. I had two 10's there for a few weeks and didn't like it so I scrapped that set up and went a little bigger and put a box in the ttop well.
Old Jan 16, 2011 | 12:06 AM
Vmineo's Avatar
In the fenders or building a box behind the dash which doesn't always work out good.The only other options if you don't want them in the trunk.The gas tank is right under that hump and 99% people screw into it and put a hole into the tank
kjcmusic17's Avatar
do you have any pics of your 2 10s back there?
Old Jan 16, 2011 | 12:52 AM
cfallsguy's Avatar
I don't, it was awhile ago and it was a crappy setup. Basically two 10's in a sealed box sitting directly behind the seat. Any reason for wanting to locate them somewhere else or just curious?
Old Jan 16, 2011 | 01:04 AM
9WhiteCamaro9's Avatar
I had two 12's sittin behind the front seats at one point. I had the back part of the back set laid down and I built a box for the subs and had the box sittin on the flat part of the back seat. I later sold everything including the box, subs, amp for a little more than what I had in the whole set-up. Now I'm just running after market speakers in place of the factory speakers and does me just right. Everyones different though.
Old Jan 16, 2011 | 01:17 AM
kjcmusic17's Avatar
Mainly curiosity and the fact that I'm a little OCD so I'm not happy with just one sub in the cubby hole because it's not symmetrical. I'd rather have two subs somewhere but I don't wanna sacrifice my storage area so I thought, "why not on the hump?"
Old Jan 16, 2011 | 08:29 AM
cfallsguy's Avatar
I've seen stealth boxes for both the drivers and passenger side but I'm not sure how hard it is to find one for the passenger side.
I had a setup like this as well and I'd say that was the worst sounding spot I had them. It was night and day difference between there and in the ttop well so to OP I wouldn't go that route.
Old Jan 16, 2011 | 09:03 AM
1sicLS1's Avatar
I did it.... I'll tell you this I had so many compliments for the best SQ in a camaro, now if your looking for SPL this wouldn't be the best idea. Wasn't a bad install, as you can tell this is old school (hence the playstation lol), this was my first camaro a 94 3.4L lol. Miss them days....
Old Jan 16, 2011 | 09:40 AM
meine96ws6's Avatar
I guess I might be able to answer your question about placing the box on the "HUMP".
This SEALED box contains ..2 (12") clarion xw-series woofers... 2 (630 watt) clarion amps.
all together this set up has put out over 144.2 DB's with minor adjustment on the amps. That is way louder then you will ever need to play music.
Old Jan 17, 2011 | 08:55 AM
IROCSS's Avatar
Rear seat delete may give a good starting base to build from
http://www.rearseatdelete.com/camaro4.html
for a gto but would be a nice wall
http://www.rearseatdelete.com/gto.html
Nice lookin set up
http://camaroforums.com/forum/showthread.php?t=22119
Hope this helps with some ideas.
Old Jan 17, 2011 | 06:11 PM
brutalis's Avatar
I thought the exact same thing, so I built a box (fiberglass and mdf) myself that holds a single 12 and 2 small amps. It sits flush with the top of the back seat heightwise, and matches the contours of the plastic panels on the sides. It doesn't obstruct my view out the back at all, but I can still see it (and smile) when I look in the rearview. While I don't listen to it cranked up (the bass boost on the amp is off), it looks and sounds great, plus I have the satisfaction of knowing that I did it myself. It was my first experience with fiberglass, so the finish wasn't great, but I wrapped it in matte black vinyl, so it wasn't a big deal. I don't remember the volume offhand, but it was somewhere around 1.2 cu ft, which is plenty for a small 12 in a sealed box. I'll get some pics up later
Old Jan 18, 2011 | 01:00 AM
Vmineo's Avatar
Default re
You could always mount them like this,hardly know its there
Attached Thumbnails Alternative Sub location-22578_1265994422124_1597688997_693944_7030963_n.jpg   Alternative Sub location-39458_185168661493740_100000018227599_661703_5918374_n.jpg
Old Jan 18, 2011 | 12:44 PM
bad_408_vert's Avatar
Look into slimline subs so you wouldn't need a tall box that would block your view from the hatch.
Old Jan 19, 2011 | 12:21 PM
brutalis's Avatar
As promised, pics:
Hard to see the contour, but it fits right along the panel
Sits flush with the back seat. You can see it, but the view out the window is unobstructed
Old Jan 19, 2011 | 05:28 PM
kjcmusic17's Avatar
Brutalis, that's exactly what I'm looking to do! Thanks so much! Is that a box and then contoured side pieces or is it all one piece?
Old Jan 19, 2011 | 10:27 PM
brutalis's Avatar
A bit of both. Its an mdf box the width of the top flat, but the bottom sheet is oversized and cut to contour with a bandsaw. Then i put in some small sheets at an angle to hold the amps (the second one isn't in yet) and pulled fleece over the whole thing. Cutting and sewing the vinyl was the hardest part, honestly.
