Messed up the "Novak Jack"... Need a quick bit of help
Question is, on the main radio board the white connector that appears to be stuck to the board appears to have the weird connections where push a wire in and there are little metal teeth that bite into the wire and then you cant pull it out.
So I just pushed my new wire in in place of the old one I accidentally ripped out. What are the odds of this actually working? Im still at work and decided id post up here if someone knows its not going to work so I dont haul the radio home install it, realize it doesnt work, then bring it back tomorrow to fix it..
Anyone else screwed this up?
