Looking for install kits
Old Feb 13, 2004 | 10:13 PM
Fierce-LS1's Avatar
Default Looking for install kits
Just bought a din head unit. Where's the best place to find a good metra or best kit unit. Do they still have the ones with a little opening on the bottom so you can store things under the DIN headunit ??
This is for a 2002 Trans Am.
Old Feb 14, 2004 | 12:49 PM
maddboost's Avatar
The metra kit that they make for the TA doesnt have a pocket its a flat panel. Kit will run you about $15.00 you also will need a wiring harness which will be $15.00, and a antena adaptor wich will run you $10.00.
Old Feb 14, 2004 | 04:53 PM
ls1camaross's Avatar
You can normally pick up a Metra kit at any local places. I picked up a dash kit and an attenna adapter for just a little bit over 30 bucks.
Old Feb 15, 2004 | 10:11 PM
D Rock's Avatar
Which kit is the one that comes out a little bit, doesn't fit back into the stock peice, but comes with a new trim peice.
Old Feb 15, 2004 | 10:20 PM
maddboost's Avatar
Old Feb 16, 2004 | 07:18 AM
LS1Baron's Avatar
The Metra kit you're looking for is available as part number 99-4544. That is the kit with the pocket.
