Easy wiring question
Old Mar 7, 2011 | 01:02 AM
booch137's Avatar
Default Easy wiring question
I don't know jack about wiring but I just swapped an LS1 into a v6 Camaro and need to run the INJ2 wire from the fuse box to power half the coils, etc. Can I splice the INJ2 and INJ1 wires or will the coils lose juice by doing this? The v6 only has the INJ1 wire to power all 6 cylinders but the LS1 uses the INJ1 for one side and INJ2 for the other so I have to add an INJ2 wire and fuse to the fuse box then run it to the fender well connector that goes to the PCM. The wire would be spliced before the connector.
INJ1----\(splice)----->Conector----->PCM
INJ2----/
