upgrading my sound system
I have noticed that there is feedback through my speakers especially now that I don't have a HU installed. It varies with my engine RPM. If my RPM increases, the feedback/static noise increases. So I think I'm going to route my RCA cables down the driver side. Should this help with the noise?
EDIT: I checked out the link you provided. How are these cables? Seems it MIGHT help with my noise problem, plus it's 4 channels into one which might keep the cables cleaner.
(non-sponsor link removed)
Last edited by WhiteBird00; Mar 29, 2011 at 07:33 AM. Reason: non-sponsor link removed
I would still run 6 channels, not just 4. I would buy an additional 2 channel cable.
That cable should work, the length is good. I don't see an activation wire in the molding. If there isn't one, be sure sure to get a spool of cheap automotive wire, 18-22 gauge is fine, and run it with the RCAs from the HU to the back. This will act as a simple on/off signal from the HU's "remote control" output on the harness.
There is already a remote (blue) wire that runs with my power cable for the amp. It is spliced just behind my HU so I will just make sure to cut that wire and hook my HU to that as the amp already is spliced into it. I need to get me a good wire kit and crimps as well.
EDIT: What guage does stock wiring use? I don't know if having a different thickness is a good idea or not.
The stock speaker wiring is pretty thin, less than 18 gauge, I think, maybe 22. You can never go wrong using thicker wire, but a GOOD 16 gauge speaker wire should adequate for your increased wattage. Knukonceptz also has some nice, pliable, above rated gauge speaker wire. Not pushing their stuff, but it it is good quality at a reasonable price, IMHO. Monoprice is good for bulk wire and home theater stuff. They are a favorite vendor on home audio forums.
EDIT: Another dumb question. Where is a good place to get some extra wire to extend my IGN, Remote, Ground, and whatever else type of wire? Also what place sells some good wire crimps? I don't want cheap ones that will crack or not hold the wire. I hate the twist cap ones.
EDIT: Finally found the thread I was searching for stating that this will work. I knew I found the thread sometime in the past. I'm going to go ahead and get the harness so I don't have to cut up the stock wiring like I had to in my old '89 Camaro.
I forgot you bought the special HUMOUNT, and maybe didn't include a pig tail half... so yeah, probably need that metra bought separately. ...you could get by without it, just consider which pins you still need, like power antenna, etc. (camaros don't need?) Forgot that you don't need any of the speaker outputs anymore. Just go through the FAQ pin out carefully and consider which ones you still need. The metra adapter would make a neater install.
