Need Help! No Power to fuse box!
Old Apr 3, 2011 | 05:08 PM
corpserodeo666's Avatar
Default Need Help! No Power to fuse box!
Ok, So I am getting no power to the fuse box under the hood. I have tried everything. Could it be a bad relay? Or a bad fusible link? Please help I can't figure this out and I have searched. Thanks in advance.
Old Apr 3, 2011 | 08:47 PM
pentavolvo's Avatar
fusiable link is most likely culprit
Old Apr 3, 2011 | 09:23 PM
I'll cut that bitch out. It's the 3 wire one that goes to the fuse box right?
Old Apr 4, 2011 | 07:31 AM
WhiteBird00's Avatar
Ungrounded Moderator
Don't do that unless you like the idea of watching your car burn to the ground. The fusible links are there as a last line of defense to protect the electrical system from significant shorts. If the fusible link is burned out then you have a major electrical problem that you need to find and repair first. Then you need to install a proper replacement fusible link.
