Brake light problem?
Old Apr 13, 2011 | 05:10 PM
BlackBirds's Avatar
Default Brake light problem?
Today I noticed when I turned my ignition on my passenger's tail light was lit up, but my driver's wasn't. When I push the brake pedal both lights light up as normal, but when I release it the passenger's tail light stays lit up. Does this indicate a fuse is blown or something like that? This car is a project drag only car, so a lot of the wiring inside has been unplugged, does anyone know why one brake light would come on when the ignition is turned?
Old Apr 13, 2011 | 06:02 PM
BlackBirds's Avatar
i also noticed when i step on the brake pedal with the ignition is off only the driver's side comes on
Old Apr 14, 2011 | 11:17 AM
wssix99's Avatar
Save the manuals!
Bad wiring. There is a connector to the rear harness just inside the hatch. If you test the circuits there, it will tell you if the problem is in the tail harness or further forward in the car.
