why is my subwoofer doing this????
Old Apr 18, 2011 | 03:51 PM
C Murda's Avatar
Default why is my subwoofer doing this????
i dont think what equipment i have matters but i got a power series rockford sub dual voice coil running off a rockford mono amp and even with the volume turned all the way down and gain on the amp itself set at its regular setting i get massive THUMPS from the sub whenever the headunit powers on or if i click a button on it or if i even plug in my ipod its such a massive feedback sound and sounds really bad like its gonna blow something? what could be wrong???
Old Apr 19, 2011 | 10:05 AM
KipMaslonka's Avatar
Check your grounds I think. If you know anyone with an amp you could swap into your system, try theirs
Old Apr 19, 2011 | 08:02 PM
KEE AUDIO's Avatar
Check and see how long the ground wire is. It should be very short.
The amp itself could be having issues as well.
Old Apr 20, 2011 | 05:37 PM
2001-CamaroSS-LS1's Avatar
definitly sounds like a ground problem..make sure the place when you have the ground connected too is clean bare metal
Old Apr 21, 2011 | 04:09 PM
habeba86's Avatar
Guessing you have an aftermarket radio? What brand?
Old Apr 28, 2011 | 02:20 PM
C Murda's Avatar
pioneer head unit forget which model... the ground is VERY short maybe 6" but im thinking it may not be a GREAT ground so ill check that out first. i REALLY hope its not the amp cause that damn thing is expensive...
