perimiter sensor
Old Feb 21, 2004 | 12:01 PM
swandogg25's Avatar
Default perimiter sensor
Anyone have the how to link to install the DEI 508D perimiter sensor to a stock alarm? Thanks
Old Feb 23, 2004 | 03:23 PM
swandogg25's Avatar
Im useless. I should get rid of my crappy stock alarm.
Old Feb 23, 2004 | 06:43 PM
maddboost's Avatar
Shawn I have never hooked up a DEI perimeter to a stock alarm but I would recommend looking into getting a full on aftermarket alarm from DEI. I can certainly hook you up on the price. And if you want to have us install it my buddy Kyle that installs at our Fox Valley Tweeter does really good work.
Old Feb 23, 2004 | 08:54 PM
swandogg25's Avatar
A new alarm is not in the budget right now.
There was a write up on how to add it. Lost the link. You tap into the wires that run to the shock sensor in the rear. I just don't remember what color wires were which.
Old Feb 24, 2004 | 12:27 PM
WhiteBird00's Avatar
Ungrounded Moderator
From the FAQ on LS1.COM...
DEI perimeter sensor installation
Not much to this at all. You mount the sensor under the upper portion of the center console. I typically mount them on top of the ABS sensor. This way you only have to remove a portion of the console and not the whole thing. You then extend the wires back to the factory shock sensor, You can find the same wires in the passenger kickpanel but since the kickpanel is off anyway I think its easier to just run the wires back. It takes all of an extra 5-10 secs. After you have go the wires to the factory sensor splice them in as follows.
DEI....Factory Sensor
red -- orange
black - Black
blue - green
green - blue
Refer to the manual it came with to adjust the sensor.
You could add a second shock or any other sensor that has negative outputs instead of the perimeter sensor or you could just replace the stock one with a better aftermarket one.
Old Feb 24, 2004 | 04:04 PM
swandogg25's Avatar
Thank you whitebird! Appreciate it.
I bow to the almighty Phil!!!!
Old Feb 24, 2004 | 04:06 PM
maddboost's Avatar
Dont worry Shawn Ill buy you a drink or two at the next Hooters gathering.
