2000 Camaro Audio Problem
Old Feb 22, 2004 | 08:10 PM
RjKc17's Avatar
Default 2000 Camaro Audio Problem
Ok, I read the huge thread by Rogue that was awesome. It helped me out a lot. I have another question for all you people with the same problem I'm having though.
The other speakers in the car are easy to replace and wire up....
I CAN NOT FOR THE LIFE OF ME, FIND 6 OR 6.5 INCH SUBS TO FIT IN THE SAIL!!!!!!
The RFP4406's and RFP3406's are all discontinued and I can't find a place online or local that has 2. Crutchfield had 1... but what good does 1 do me.
I've tried 9-12 places online now with no success.... As I see it, I only have 1 viable option.
Kicker makes a couple different 6.5 midbass speakers, my question is will these work? If so, which model would you recommend. Is it a true Sub that's in the Sail or is it a midbass? I'm not well versed in car audio electronics, I don't know the in depth details so laymen terms will be very well appreciated. Thank you for any help you guys have for me.
R.J. Casey
Old Feb 23, 2004 | 07:20 PM
Cali99SS's Avatar
I believe the speakers in the sail are 6.75 not 6.5. I had to make an adapter using sheetmetal. I put sound dampener behind the sheetmetal so there wouldn't be any vibration. It worked out pretty good for me.
