Monsoon Subwoofer replacement
I see no reason to upgrade my amp at this point, but both of my 6.5 inch subs are trashed, I called gm and the replacements are $87 a piece which is a little steep for a paper cone. So I would like to know what people with the stock system are using. price range is around and under (if someone has a secret nice low price one) $100 per side. Lets see what you've got.
It was a huge fight with Marketing to keep Bose out but I finally convinced them to go in a different direction!What I can say is that Monsoon is definitely a "low cost" speaker and $87.00 is definitely making a nice profit margin if that's what they are trying to charge you to replace them.
You should be able to replace it with any aftermarket speaker that is the same size. Just make sure you match the Ohm's so the volume will match around the vehicle when you crank up the sound.
As for the amp, there is not really a need to replace it if you get a good head unit to do your filtering pre-amp.
