fans click off without control
Old Jun 8, 2011 | 02:55 AM
-M-'s Avatar
-M-
Default fans click off without control
Once the car is warmed up the fans wont come on unless i restart the car and then they will only come on for a short period of time (5 seconds or so). I replaced the relay and it did it again....
However I was looking at installing dual fans and was wondering if I could use the fog light wiring as I dont use them and dont plan on it... Doing so would allow me to use the fog light switch to turn on and off the fans....
Im looking for a short term fix so I can get elbows deep and find the reason my relays keep blowing when the fans come on
Old Jun 8, 2011 | 03:00 AM
MikeyZ's Avatar
why not run right of the battery to a switch to your fans? get an inline fuse though
Old Jun 8, 2011 | 03:06 AM
-M-'s Avatar
-M-
because the wiring for the fog lights are in place. stock switch, its already wired up, its on a relay with wiring that works and as long as its on the fog light switch I could leave it on and not worry about it draining my battery if I park the car for the night....
Like I said, this will be the short term fix... if I change the fuses to handle the fans would all be ok?
