Putting Stock Back In
Old Jun 29, 2011 | 08:18 PM
ls1jorge's Avatar
Default Putting Stock Back In
Putting Stock back in
The previous owner to my car installed sony radio, he cut off the factory harness & rewired the actual harness for the Sony & I ended up buying the car w/out a radio, I jus recently bought a 02 factory Monsoon & my concern is if I were to go to a junk yard & come across a 94-97 Firebird/camaro that has the factory harness to plug into the back of the headunit will it have the same connection as the 98-02?
94-97 camaro/firebird harness connection
98-02 firebird/camaro harness connection
98-02 monsoon radio rear connection
Old Jun 29, 2011 | 09:28 PM
TheHeadFL's Avatar
That is the same connector, as far as I know.
The harness adapters for aftermarket stuff are always labeled GM 1988-2005.
Old Jun 30, 2011 | 01:34 AM
01ssreda4's Avatar
Thats a standard GM 21 pin plug. They used it for about 20 years. Its in probably half the GM vehicles in the junkyard. Look for anything late, late 80s up to probably mid 2000s. They are in trucks, cars, vans, anything GM, Pontiac, Olds, Buick, Cadillac, all of them. You want the part he cut out of the car, so just find a car with no radio, locate the big connector for the radio and snip it out. Then you can go and splice it back into your car's wiring to make it accept OEM radios again.
Old Jun 30, 2011 | 08:52 AM
ls1jorge's Avatar
TheHeadFL & 01ssreda4
Alright thanks for the info, I'll be headin to the junk yard on Saturday, & what's that other connection for on the far left side??
Old Jun 30, 2011 | 09:25 AM
TheHeadFL's Avatar
CD changer I am guessing?
EDIT: *Far* left is antenna. I assume you meant the other one.
Old Aug 11, 2011 | 06:45 PM
sean2010's Avatar
okay so will any gm radio plug work with my 1997 trans am? i have the monsoon system so i need the factory plug that goes from the amp into the back of the radio.
Old Aug 12, 2011 | 06:54 AM
WhiteBird00's Avatar
Ungrounded Moderator
Almost all 1.5 DIN GM radios from 1988 through 2005 use that same connector. The double DIN radios are completely different. That still leaves the vast majority of GM models for that time period.
You can also buy a new connector pigtail for around $10. It's Metra part number 71-1858.
